Engine noise after oil change
Originally Posted by newmandl
I know that when you change oil, there engine is without pressure for a few seconds until the new oil is picked up and pressure is restored. Might make a little noise, but should not be excessive.
Sounds like he installed a dry filter. I always fill the filter up then install it. Some will leakout due to it being tilted as you screw it on plus less air in the oil system before it gets vented
I'd also make sure that he installed the right filter too. Heard the wrong one will make it knock too.
Thanks, I will try those 2 ideas on next oil change....makes sense.
Originally Posted by mustangraven
I dont know where you live but 5w-20 oil is awful thin. I would only go 5w-30 myself but I am in NY
This works
Get a standard key cut to match your Pats Key ------ next time change oil and use this new key to turn over engine (it will not start with this key) until the oil light goes out. This may take several rpms using only the starter but the light will go out as soon as oil is picked up, now the oil filter is full and pressure in the engine. This stops dry engine start up after oil changes.
Great idea!! Thanks
It's a good idea to run your engine right before you change the oil, so that the internals are already wet. So when it runs dry for a while, it won't matter cause the engine hasn't been off but a few minutes. But it's probably not a big deal. My jeep ticks constantly.
