Turning on 4x4
You can switch from 2WD to 4WD High or vise-versa at will, moving or not, as long as you do not the exceed max speed warning on the drivers side sun visor. I'm certain this warning is also stated in the vehicle's manual. I can't remember the max speed you can switch at, but like I said, it is on the sun visor or in the manual. Why there is a max speed, or what the consequences of switching above that speed are I have no idea. I personally would not recommend not heeding the warning.
Concerning 4WD Low. You can not switch to Low Range without coming to a complete stop first. You also need to come to a complete stop when switching out of Low Range. This is because of the changing of the gear ratios going from High Range to Low Range. You probably need to shift in to neutral or park before switching in or out of 4WD Low. I don't remember for certain, but I always put my truck in neutral when going to or coming out of Low Range.
Hope this helps,
Mike
Hope this helps,
Mike
Hope this helps,
Mike
Hope this helps,
Mike
If you did not get an owners manual, you can download one for free at www.motorcraftservice.com in the owners section. It will be in PDF format.
