05-08 4.2 Throttle Body Cleaning
I was told on these "fly by wire" throttle bodies, you are not supposed to EVER manually move the throttle body butterfly. On my 2005, I had the infamous "going down the road and it just dies" condition happen, one of the suggestions I got here was to take it out and clean it. I did it, and it didnt help, and after the fact found that you are not supposed to manually move the butterfly on these things.
I ended up replacing it with one out of a 2007 and it's been fine ever since. It is dirty again and I wanted to clean it, but still working fine, I think I will just leave it.
Well, that is a double edge sword. When cleaning the TB still on the engine it's better to do so right before an OCI. Also, any debris that is washed into the intake will burn off in the cylinders, which in turn can only help clean the intake valves.
