Overdrive light blinking????
Old 08-16-2000, 12:24 AM
RkyMtnFordFan's Avatar
Red face
I had the same problem come up last week and took it in..after I checked here for comfort and suport. Heres what they did (right off the work order)
EEC TEST P0781 TRACE TO 2-3 ACCU LEAKING. ROAD TEST RUN ELECTRIC TRANS DIAG. PINPOINT TEST C TO 2-3 ACCU PISTON. R AND I 4R70W TRANS PAN AND VALVE BODY AND REPLACE 2-3 ACCU PISTON. ROAD TEST AFTER REPAIR. CLEAR CODES RETEST OK NOW. 5013
Anyway same symptons and this seems to have fixed it. Very cool that I had the problem, came here and instantly had an idea what was up b-4 the dealer looked at it.
1999 oxford wht F150 s/c, 5.4, XLT, ORP, Alpine/Infinity, K&N
Old 08-16-2000, 08:35 AM
MNFORD99's Avatar
Thumbs up
Rkymtnfordfan-
Glad that there was a post similar to the problems that you had....since I made the first post, it came back on, they were going to replace the cylinoid, and then the torque converter....got my truck back yesterday after a 7 days in the shop, and they ended up putting in a "new" re-built transmission in it......not happy about that, but then agian I haven't been too happy with this truck either....but I am still a die-hard Ford man....nothing but the best!!!
Old 11-17-2009, 03:57 PM
MR03SVT's Avatar
my 2003 lightning is having this problem with the overdrive light blinking,but it seems like all i have is second and reverse gear..
Old 11-18-2009, 12:46 PM
glc is offline
1. This thread died over 9 years ago.
2. Go to a shop that has an OBD2 scanner that can read manufacturer-specific codes and get them read.
Old 05-19-2011, 08:27 AM
Jay_13's Avatar
Hi all, new member here....
I've been having a similliar issue with the O/D light blinkinng for almost a week now. After reading through this thread, I tried to pay more attention to when this is happening:
It does seem to be shifting harder than it should, especially down shifting. This morning on the ride to work, I could not get it to go off. I took it easy at first getting up to 50 mph, then I tried to make it go off(By nature I'm a casual driver). So I pegged the tach up to 3.5k and it still didn't go off?
Unfortunately I work pretty close to home, so I didn't have a great deal of time to try to recreate the issue.
It seemed last night that it was going off @ 2-3 gear shift is there some kind of sensor to check?
Old 05-19-2011, 01:23 PM
glc is offline
You need to GET THE CODES READ.
Old 04-09-2015, 10:29 PM
Dzire19's Avatar
How much for 03 f150 tranny??
I have read every single post. I am convinced there is no simple fix.
Old 04-09-2015, 11:04 PM
glc is offline
You might get some help if you started your own thread with details of your problem and trouble codes, if any.
Old 04-10-2015, 09:22 AM
Darrin Burch's Avatar
Simple fix for what specifically? There are many potential causes for a flashing OD light. We have literally no info to go off of to help with yours.
D
Old 08-06-2016, 02:28 PM
1995f150302's Avatar
1995 f150 5.0
My trucks abs light brake light and the over drive light is flashing and the transmission is just fine and don't know what's wrong
Old 08-07-2016, 09:02 AM
Mark Kovalsky's Avatar
Nobody knows what's wrong. If you get the codes read then we can tell you where to start. You need somewhere that has a good scan tool, the auto parts stores that read codes free CANNOT read these codes. You need either a good independent shop or a Ford dealer.
Old 07-06-2017, 08:11 PM
C. Prince's Avatar
Originally Posted by Paveman
My 97 F-150 has had the same problem with the OD light flashing but with a twist. My trans jerks when it shifts as well. I took it to the shop and told me to just change the fluid and filter. I did and it drove great for two days and then started up again. I thought maybe it was the trans heating up, but again you can turn the engine off and then on again and everything is fine. I'll be taking a look at the sensors next.
Did u ever figure it out? Mine is doing the exact thing, slight jerk when shifting and O/D light flashing. Any help would be appreciated
Old 07-06-2017, 09:48 PM
glc is offline
That was posted 18 years ago.
You need to get the codes read with a scanner that can read Ford transmission codes.
Old 10-04-2017, 09:16 AM
Trenton Hammond's Avatar
i have a 1995 f150 mark lll conversion and the light started flashing a week ago but it stalls in first then i have to let off the gas a bit to make it shift into second and overdrive, plus it slams through every gear and if i let off the gas or brake in overdrive it wont shift back into it. the other problem is it slams into reverse and drive everytime, i dont know if i need new button or my trans checked out
Old 10-04-2017, 10:28 AM
glc is offline
Check the codes.
Quick Reply: Overdrive light blinking????
