rebuilt 4r70 does nothing
Tranny lost overdrive so we took it apart and the clutch packs were bad. Replaced those and put it back together. As we were installing it, it fell forward and the tq converter hit the floor. Never touched the valve body, but everything worked except od before. Now nothing works. Reverse worked for a bit, now nothing. Would dropping the converter kill it? It did hit pretty hard
I assume this is a 4R70 transmission? 14 qts is correct to refill a 4R70
torque converter might be damaged, might have also damaged the front pump.
you mentioned the clutch packs, did you install new lip seals on the clutch piston?
Overdrive on the 4R70 happens by engaging the OD band... did you replace the OD band?
You'll probably have to pull the trans to figure out what went wrong. I'm sure that's not the answer you want to hear. Obviously something went wrong in the process.
I'd be inclined to install a used transmission and be done with it. You may get lucky and find one that was recently rebuilt. Or for about $1,600 you can buy a reman unit.
