04 F150 Shudder transmission??
Been a lurker for a while finally glad to have signed up for this forum. Unfortunately my first post has to be about a problem Ive been having with my truck recently.
A little background: Truck is a 2004 F150 Lariat Supercrew w/ 5.4. 2WD automatic. 155,000 miles. around 5-6000 miles ago had cam phaser replaced, spark plugs and other preventative parts that go along with the phaser. COPS boots were replaced but not COPS themselves.
I have been running an edge evolution programmer for about 2 months besides that the truck is stock.
Before the programmer was having minor problems with the transmission but really only when quickly accelerating such as on the interstate etc. truck would, "jump" into overdrive and kind of shake.
The programmer completely fixed that problem but now I have a new problem. When im at around 35mph/45mph and let off the gas for a second then push it again to accelerate to go up a hill or something the truck will shudder/bump. sometimes one time up to 3-4. feels like its slipping gears or something. doesn't do it all the time but enough to concern me.
I originally thought it was from the programmer and do plan on sending it in to get custom tunes(once I get exhaust) but today I set it back to stock and now it does it even worse!
Any ideas?
Any ideas?
im just wondering if its actually the tranny or something else. was doing some reading with people having the same problem saying it was a bad COP. Guess I just want some more opinions, the whole shudder thing just recently started past week or so. I bought the programmer for the performance and fuel economy.
honestly I think the jumping into od part is just the because im an aggressive driver. Not sure if the fluid has been changed or not but probably not honestly. Im just unsure of what to do. Ive read both sides about the edge, some say it will make the tranny last longer and some say it destroys it, but general consensus is custom tunes is the way to go. I plan on getting bilstein 5100s installed soon so I guess ill ask the shop what they think when I get that done. I just don't know if I should leave it stock programmed or run the edge. It does not do it as much with the programmer but at the same time if it is a problem with the tranny I don't want to mess it up even more with the edge.
there was a thread on here a few months back i followed pretty closely about the shift firmness option on tuners. what i got out of it was that if you set it all the way firm its not slipping as much and will last longer, but in my opinion the shift shock could cause problems. orrrrr if you go the less firm route, it increases slipping, but in my opinion it may mask a little slipping if its started.
if it were me id throw it back to stock if you can and see what happens. also cold vs warm
how were the tranny settings on the programmer?
and careful with the tranny fluid. most guys say to get it drained and refilled 3 times vs a flush with chemicals.
others also say the tranny will get worse after a fluid change due to the bits and pieces in the current fluid holding everything together
Others are wrong. There is NO truth to that. Bits and pieces do not hold a trans together. It's an old wive's tale.
Your tranny is going dude. Mine was doing the same thing for a couple of weeks and then 3 nights ago it went within 170000K on it. It would would even move when in gear. At highway speed, when letting off the throttle a bit, it would shake like a son of a bitch. Felt like the truck was going to fall apart. I guess the 04 tranny is year specific. Just found one with 98000K at a wrecker and having it shipped to me. Damn costly fix.
Just a little update guys. Im going to order the shocks this week. I wiggled the cop boots and ive been running the edge and it only occasionaly does the shudder thing only one "bump" now though so not as bad as before. Really thinking/hoping its just the cops an not the tranny. Im also going to clean the throttle body and MAF (can't hurt an sure it needs to be done anyway) Will also change the fuel filter when I have the shocks done. Then have the tranny fluid flushed. If the problem continues then ill just replace all the cops with accel super coils. Ill keep yall posted.
