2wd to 4wd swap problems
Old 12-18-2012, 09:38 PM
fordjohn's Avatar
i got a 96 f150 2wd with 5.0 with 4r70w automatic trans converted it to 4wd from a 93 f150 with 4.9 e40d automatic trans changed the computer from a 96 that had the e40d trans and 5.0 moter so the problem i am having is trans will not shift right i know there is nothing wrong with the trans b\c drove the 93 with no problems for several months any ideas on what i ouer looked on swaping out
Old 12-19-2012, 10:55 AM
Mark Kovalsky's Avatar
Did you change the wiring? The pinouts are different between the two transmissions.
Old 12-19-2012, 09:18 PM
fordjohn's Avatar
changed the harness from trans to where it plugs innext to the air box
Old 12-19-2012, 09:53 PM
You need to see if the engine harness to PCM connector pinouts are different. You might need to move some wires.
Old 01-03-2013, 09:16 PM
fordjohn's Avatar
checked the two plugs they are a little different from each other the 93 that the trans harnes came out of has some light blue wires but the 96 dose not have tried to get a wire diagram from the ford dealer but only thing they showed was the harnes as a whole not the colors of the wires dose any one know where i can find that info
Old 01-04-2013, 11:43 PM
Wiring diagrams are available at www.helminc.com and www.atsg.com.
Old 01-07-2013, 12:34 AM
JMC's Avatar
JMC
JMC is offline
Does the car PCM know you have truck tires (i.e. different size)? Different rear axle ratio?
Old 02-05-2013, 08:42 PM
fordjohn's Avatar
the tire size and axel will have nothing to do with the problem i am having checked the wireing diegram and it only shows the pin locations on the trans plug end not were the two harness meet
Old 02-05-2013, 11:19 PM
JMC's Avatar
JMC
JMC is offline
What do you mean trans will not shift right? What is the 96 PCM out of?
Old 02-12-2013, 09:08 PM
fordjohn's Avatar
i changed the pcm it came out of a 96 bronco 5.0 with a e4od trans but it shows trans codes p0708 p0743 p0755 p1747 p1754 on the pcm did not have any probs when this was in the other truck when u put in drive and try to move it like u are holding the brakes
Quick Reply: 2wd to 4wd swap problems
