F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 06-25-2009, 12:51 PM
Vehicle: 1999 Ford F150 4x4
Toque Converter Lockup Indicator (and Switch)
I was hunting around for a way to determine when my T/C goes from locked to unlocked when towing (other than watching for the slight tach increase), and knew there had to be a signal to the T/C lockup solenoid. Well, I found THIS POST at TheDieselStop.com detailing (I mean really detailing) the addition of an LED. I found the wire in question at connector C172 on the passenger side of the firewall. (Its' a grey connector under under a snap-off plastic cover/metal bracket assy.)
The discussion also gets into adding a T/C lock-up switch, which I think could come in handy as well, but I'm hesitant to install this. I assume Ford knew what they were doing when they programmed the PCM to lock/unlock it under certain conditions (and I don't see any long-term reports on the effects of the manual override switch in the linked post). It would be nice, though, if the trans would downshift directly from OD to 3rd without the "3.5th-gear" slip mode. It might also be nice to get a little dynamic braking?
I'll be adding the LED, but would like to know others' thoughts on the switch.
Andy
Old 06-25-2009, 02:12 PM
Vehicle: 2001 Ford F150
The reason the 4R7x transmissions take a moment to downshift from 4th is because the transmission needs to fully release the overdrive band before the forward clutch comes back on. If that doesn't happen then the transmission becomes mechanically locked. Kind of like park and is bad.
I have 0 opinion on a light or switch though, I only wanted to address that one concern that you voiced to try and explain why it has to be that way.
Darrin
Old 06-25-2009, 03:05 PM
Vehicle: 1997 Ford F150
Wow, that's some deal there...
While I can appreciate the function of this mod, and in a diesel, it probably makes sense, since the rpm range on one is very small compared to a gas engine.
In my case, I've become so accustomed to the shift patterns of my truck, that I can tell what's going on pretty much by feel now... Then, it only takes a second to blip the gas to check the tach since I'm already looking there anyway!
My vote is to leave the wiring harness alone and I don't even like the idea of a tuner, so that'll tell you where my 'conservative' mind is!!
But more power to those that have the gumption to do this kind of stuff!
Mitch
97 F150 XLT 4x4 Super Cab 5.4. 200,000 miles, trans code "E" (E4OD). 3.55 LS, LT265/75/16 WILDCAT RADIAL AT's. Autometer Water/Trans temp gauges.
Old 06-25-2009, 03:09 PM
Darrin
Well, it sounds like having an override switch activated would be a bad (possibly very bad) thing if the trans wanted to downshift out of OD, then. Trouble is, though, it's not just an OD --> unlocked --> 3rd shift. It seems like it likes to stay in the unlocked condition too long (or at least longer than I'd like it to). As soon as I see the tach jump, I hit the OD button, and knock it into third. Maybe I'm exhibiting some "conservative-ism," too.
Regardless, that pretty much seals the deal against the switch for me. The light OTOH, couldn't hurt anything.
Thanks.
Andy
Old 06-25-2009, 03:11 PM
Noting wrong with conservative, so long as it doesn't slide over to paranoid fear.
Unfortunately, I don't tow enough with mine to get the "feel" for it, so the light will be a better indicator for me.
Andy
Old 06-25-2009, 03:41 PM
Mitch
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
