F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 02-22-2008, 01:22 PM
Should I change transmission fluid-Read this:
I have a 2005 F150 scab. I bought it used and it now has 41,000 miles. I am going to be pulling a 23 travel trailer a lot this year. I was going to flush the transmission myself using the article from Ford Truck Enthusiasts that everbody has referred to then I found this article.
http://www.ford-trucks.com/specs/2004/2004_f150_2.html
It says with the 4R75E transmission the fluid should last the lifetime of the truck. What is your guys opinion? I was going to flush it out and replace with Mobil 1 synthetic.
Old 02-22-2008, 02:11 PM
FLUSH IT!!
Towing is exstream useage. Nothing is forever. Sure the fluid with last a lifetime.....the life of the trany.
44
"Smok'in the competition NOT Tobacco"
"Transplant organs, Don't bury them!"
Old 02-22-2008, 02:16 PM
Vehicle: 07 King Ranch
Quote:
Originally Posted by 44dwarf
FLUSH IT!!
44
That was funny, true, but very funny.
Old 02-22-2008, 05:09 PM
Can you do the same flush yourself in the driveway using the post everyone has used? Has anyone tried this in their driveway on a 2004 or newer transmission? I hate to let any of the moron mechanics at my local dealerships touch my truck.
I had an issue with the vacuum hoses on the 4wd while in warranty and it took them 3 trips and keeping my vehicle for a week. I told them about the tsb I saw on here then they fixed it in a day.
I know how they can use bulk fluid and put cleaning stuff in there that I don't want.
Old 02-23-2008, 06:04 AM
Vehicle: 2007 Ford F150
When my '07 was still brand new, at or about 3,000 miles, my local Ford dealer flushed out the factory filled Mercon & replaced it with Royal Purple. I also replaced the OEM MotorCraft motor oil and rear differential gear oil with Royal Purple. I also swapped out the MotorCraft oil filter with a K&N. It could just be psychosomatic, but I seem to think that the truck is running & shifting better. It won't hurt you to dump the old ATF & replace it with a high grade synthetic. Royal Purple, Mobil 1, Amsoil, Lucas Oil......they're all good. Read enough of these forums, and you'll find all sorts of opinions from different people as to why they feel that one brand is superior. However, you won't find any testimonials as to any one of these name brands being inferior. I have yet to hear of a failure directly related to the use of these fluids. Even MercedesTech pointed out that engine sludge in the Mercedes engines was caused by the long oil change interval recommended by Mercedes, and not the Mobil 1 oil. I wonder what Toyota's excuse is for sludge in their engines.
Old 02-24-2008, 02:35 AM
Vehicle: 1999 FORD F150
Quote:
that royal purple is good stuff. That is what we ran in the racecar.
^dirtyd88 is the man^
1999 F150 4x4 5.4, T3 front end replacement (the cow killer), T3 straight rear bumper 8" drop, Skyjacker AAL, T-bar maxed, Toyo Open Country, AT 285/70/17, Flowmaster true dual exhaust, Kobalt skinny truck box, Icom IC-V8000, Cobra CB radio, tint, Yeah that about covers it...
Old 02-24-2008, 11:53 AM
Vehicle: 2002 Ford F-150 5.4L
AMSOIL baby!! The ATF rocks, and is the only way to go if you're gonna be towing. I've overheated my tranny a couple of times (240* +) with AMSOIL in it and no problems, burnt fluid, or anything.
'02 F150 XLT 4X4 SCrew. 5.4L
K&N FIPK/Amsoil Filter
Flowmaster 40 si/do Exhaust
325/70 16 Nitto Terra Grapplers
16X10 MB Motorsport wheels
4.10 Gears
Rancho 4" lift
Edelbrock Extreme Travel Resi Shocks
Autometer Carbon Fiber Oil/Trans Temp Gauges
Carbon Fiber Interior (www.dash-kit.com)
Peterson Fluid Sys. Remote Oil Filter
FTVB
Troyer Performance Electric Fans
Underdrive Pulleys
Amsoil Fluids Throughout
My SCrew'd Garage
Old 02-24-2008, 10:36 PM
Quote:
Do you have a transmission cooler?
Old 02-25-2008, 07:00 PM
That was with the stock cooler (POS), up hill, converter not locked, in the summer!! Now with my new SD cooler I can't even get the thing to overheat above 210* with the converter unlocked. I've even tried...it wont go!
4.10 Gears
Rancho 4" lift
FTVB
Underdrive Pulleys
My SCrew'd Garage
Old 02-27-2008, 12:40 AM
Vehicle: 2004 Ford F150
Send a message via AIM to Nico
And to think I start to panic when I see my guage hit 170. Around town it is normally at 135 and when I plow around 150. It hit 170 a few times on the freeway driving 70 with the plow on, something that ford and BOSS say you should not do.
Does anyone know they thermo breakdown of stock motorcraft fluid? I am going to switch to royal purple in about 1000 miles when I take it in to get done. To me its cheep piece of mind for the way I treat my truck.
Old 02-27-2008, 10:47 AM
Vehicle: 2002 Ford E350
Quote:
You have nothing to worry about. The stock fluid doesn't get into trouble until over 275F.
Old 02-27-2008, 08:42 PM
Here is the Royal Purple ATF info:
Typical Properties*
Viscosity
cSt @ 40°C 32.4
cSt @ 100°C 7.4
SUS @ 100°F 272.8
SUS @ 210°F 63.2
@ -10°C (14°F) 568
@ -20°C (-4°F) 1200
@ -30°C (-22°F) 2868
@ -40°C (-40°F) 7934
Viscosity Index 197.5
Flash °F 450
Fire °F 490
Foam Test
Sequence I 0 ml / 0 ml
Sequence II (4 sec.) 10 ml / 0 ml
Density
A.P.I. 37.8
Specific Gravity @ 60°F 0.8358
Pounds / Gallon 6.96
Copper Corrosion
3 hrs. @ 210°F 1a
*All Properties Are Typical and May Vary
Old 02-27-2008, 08:54 PM
Vehicle: 2005 Ford F150
Hey, I have the same setup and went through h... trying the do it yourself way.
So any way, I later went to work for a company which offers flushing equipment and allowed me a flush as part of my training. I can tell you that on my truck it required some power braking to get the trans fluid to flow, it just does not move too well at idle. If you have a lift you can pick up the drive wheels to let em spin also. I am told this system has a thermostatically controlled trans cooling loop that restricts flow 'til warm, maybe someone in the forum knows where the t-stat is.
Old 02-27-2008, 08:55 PM
Send a message via Yahoo to risupercrewman
How many quarts does the 2007 take with a 5.4 3v motor?......I might do this also!.....
Old 02-27-2008, 09:07 PM
Quote:
In my manual, it said 13.9 quarts. But the MOC Flush Machine used by my dealership requires 16 quarts to operate. Don't just settle for dropping the pan and swapping out 5 or 6 quarts. Your truck is brand new. You don't need to drop the pan. There is nothing wrong with your filter or gasket. Just have them use the flush machine so that all of your OEM fluids are vacuumed out and replaced. Good luck & have fun with picking out your replacement fluids. Red Line, Lucas Oil, Amsoil, Royal Purple, Mobil 1 - quite a selection out there. Do your own research and pick one that you feel comfortable with - not just because you've heard it mentioned.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company
