transfer case indicator light
Old 05-15-2007, 10:04 PM
off road dude's Avatar
on my 97 f150 ive looked but i just cant find the sending unit on the outsiode my transfer case that tells you if u r in 4 wheel drive because i think mine is gunky because my low range light never comes on
Old 05-15-2007, 11:38 PM
Bluegrass's Avatar
You will look a long time because it's not what you think.
The motor drive that changes the tranfer case position sends the signal back from it's internal contact plate, to the GEM module.
From the Gem to the dash, then the light lites.
The only difference is a variation for the manuel shift system.
The trans selector is involved in the circuit..
Old 05-16-2007, 06:48 PM
so how would i get to it to clean it
Old 05-16-2007, 09:09 PM
JMC's Avatar
JMC
JMC is offline
Electric or Manual SOTF t-case?
JMC
Old 05-16-2007, 10:07 PM
manual sotf
Old 05-17-2007, 09:27 AM
JMC's Avatar
JMC
JMC is offline
The switch is near the breather hose on the front of the t-case. There are two wires to the switch. One is for 4Hi (gray wire) and one is for 4Lo (light blue with black stripe). With the key turned to run, unplug the connector and ground the Light blue with black stripe wire. This should turn on the 4Lo light. If the light turns on the switch is defective, replace it. If no light then more diagnosis is required.
JMC
Old 05-17-2007, 10:10 PM
you are saying the light should turn on but then next sentence your are saying if it does it is defective.
also if i go into 4 lo and then back into 2 hi my 4 hi light stays on and wont go off until the next morning
Old 05-18-2007, 01:07 AM
JMC's Avatar
JMC
JMC is offline
Unplug the connector. The connector is now in your hand and the switch is still screwed into the t-case. Ground the wire and the 4Lo light in the instrument cluster should illuminate. If it does illuminate by grounding the wires this proves that the circuit is ok. The only remaining problem is the switch.
JMC
Old 05-23-2007, 07:39 PM
jmc where can i get a new switch for cheap i tried 4 auto part stores and they couldnt find it in thier computer
Old 05-23-2007, 08:38 PM
JMC's Avatar
JMC
JMC is offline
I believe that it is a Dealer only item.
JMC
Quick Reply: transfer case indicator light
