E4OD shuttering?
Old 04-21-2007, 06:07 PM
jahwarrior1423's Avatar
E4OD shuttering?
I recently purchased a '93 5.8 4x4 with a E4OD.
I have a shuttering / hesitation when accelerating. It usually happens between 40-50mph. Ive been trying to search but cant find the cause of the problem. A guy suggested it was my OD clutches?
what do you guys think?
Old 04-21-2007, 06:42 PM
jbrew's Avatar
Did it happen after towing something for a ways?
You could have an accumulator hanging up as well- #3 or #4..
A flush could fix that. I would drop the accumulater valve body and check that out before refilling .
Old 04-21-2007, 06:49 PM
I have no idea how the truck was treated before I bought it. Got an amazing deal for the truck from a car dealer and couldnt pass it up. The truck has 120k miles if that gives some information.
I also know nothing about transmissions. What does a accumulator do?...You say look at it before anything but what is it suppose to look like?
thanks for your reply...appreciate it.
Old 04-21-2007, 07:19 PM
jbrew's Avatar
It could be the OD band as well -
check out this link for color picks of the insides of your trans and explanations - it will help -
http://images.google.com/imgres?imgu...%3Den%26sa%3DG
Old 04-21-2007, 07:35 PM
jbrew's Avatar
Read this as well - towards the bottom of the page -
http://www.tccoa.com/articles/tranny...on/page4.shtml
Old 04-21-2007, 07:45 PM
thanks...
Old 04-21-2007, 07:52 PM
jbrew's Avatar
No prob - heres a close up of the accumulator valve body w/ accumulaters - see that anodized gold stub w/nut attached - that screwed into the piston? Good , the actuall accumulator valve body is to the left of that , you can see the accumulater chambers thru the side-
Here's a pic of all valve bodies assembled (my trans was in a million pieces at one time)
This is the calibration plate that controls the accumulator valve body - this one 's a bad one , I made another (that was fun) anyway it controls flow to your accumulators and the way your trans shifts (I have the gears marked)..
Well, good luck!!
Old 04-21-2007, 08:31 PM
thanks for the clarification.
I dont think I'll be handling the job myself...if I had some of my friends help, then I may take on the job. But Im just not comfortable tearing into my tranny. I was going to call my tranny guy and ask what it'll cost for him to repair it because it may be better to just buy a remanufactured tranny if the repair costs alot.
But who knows, I may just take on the job and itll be a learning experience, haha.
One more question,
Do you know any websites or companies that I can buy a rebuild kit from?
Old 04-21-2007, 08:43 PM
jbrew's Avatar
In that case heres what I would do depending on how much I had to spend.
The only reman trans I would trust is from Jasper because of there 36 month guarentee , but that's even debatable -
http://www.jasperengines.com/transmi...automobile.htm
Rebuild kits you can get on ebay.
I would try here first - type in your zip and they find one for you close to home - a used one w/low miles would be my first choice if one can be had -
http://car-part.com/
Old 04-21-2007, 09:22 PM
thanks man...you've been a huge help.
Old 04-21-2007, 09:39 PM
jbrew's Avatar
No problem - keep in mind if you do end up finding a used one in good shape - you get to keep your old one . You can reduild at your liesure.
If you opt for a reman - they want your old unit in trade plus quite a few green backs ..
Good luck
Quick Reply: E4OD shuttering?
