F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-25-2007, 12:00 AM
Vehicle: 2000 ford F 150 4x4
Angry 4R70W shifts late into 3rd
I have a 2000 f150 with 5.4l auto. 4x4. when driving from a stop it
shifts late from 2nd into 3rd. all other gear shifts are smooth
I changed the fluid and filter with no effect. when I drop the pan, there
was no metal in it and the fluid was still clean.
could this be a solenoid problem??
help !!!!
Old 03-25-2007, 12:15 AM
Vehicle: 2006 Ford F150
What do you mean by late? About what speed or rpm is it shifting at? And do you have overdrive and is that shifting in ok?
Old 03-25-2007, 12:19 AM
sometimes it shifts at 30 mph and 3000 rpms
other times a little less.
seems if i let up on the gas it shifts sooner
overdrive and the tc lock up are fine
Old 03-25-2007, 12:23 AM
That sounds about normal too me, i dont think it has a problem. Hopefully some other will come in with some opinions
Old 03-25-2007, 12:26 AM
no its not normal..always shifted at about 22 mph and a lot less rpm..
seem to have a long delay getting out od 2nd.
Old 03-25-2007, 12:42 AM
Did you check for any DTC's?
Old 03-25-2007, 12:44 AM
Quote:
english please..lol
dtc's ?????
Old 03-25-2007, 12:50 AM
Quote:
Originally Posted by wm1s
english please..lol
dtc's ?????
LOL..sorry. Did you check for any codes (Diagnostic Trouble Codes). not all codes set off the check engine light, might be a place to start
Old 03-25-2007, 12:53 AM
no not yet.. this just started yesterday... will do that on monday.
thanks
Old 03-25-2007, 12:55 AM
Post when you find something out, I would like to know
Old 03-25-2007, 12:59 AM
i will
thanks
Old 03-25-2007, 03:48 PM
well i just checked and no codes were stored.
HELP !!!!
Old 03-27-2007, 11:14 PM
You are probably dealing with a direct clutch issue. Any pressure loss, or worn/glazed clutches can cause it. Have someone hook up a scanner and make sure TPS and MAF signals are OK. If data looks OK, may be rebuild time.
Chad
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
