F150online Forums
Look for a USED Ford F150
Carsdirect.com
Go Back   F150online Forums > Powertrain & Mechanical > Transmissions
Thread Tools Display Modes
Old 03-22-2007, 12:54 PM
Unhappy transmission will not come off.
my buddy and are in the process of removing the transmission from a 1992 ford f-150. it is a five speed manual. we have disconnected all of the extraneous material such as the reverse light wiring harness, hydraulic line, etc. we removed all bolts from the bell housing and have removed the starter as well. the rear mounting bracket has been removed and the driveshaft disconnected from the rear. all steps have been followed and double checked. the problem is that the transmission itself will not seperate from the engine block. we are at a loss and very frustrated. can anyone give me advice on this problem?
thank you
Old 03-22-2007, 01:39 PM
Vehicle: 13 FULLsize ole' Ford rigs
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
Take off the shifter?
Adrianspeeder
Old 03-22-2007, 01:51 PM
the shifter has been removed, the trans was also set in neutral before removal of the shifter. is it possible that the trans has slipped into gear, would this cause the trans to remain attached on the interior?
Old 03-22-2007, 02:12 PM
Vehicle: 2007 Ford F150
Quote:
You must be missing something . Will it wiggle or is it still rock solid?
Old 03-22-2007, 02:32 PM
yes it will wiggle, but won't slide back.
Old 03-22-2007, 03:24 PM
Send a message via ICQ to Bubbadewsky
Talking
If all the bolts and linkages are off then it is binding up between the input shaft and the pilot bearing, try lifting up the tailshaft and slidding the tranny straight back and avoid any verticle bind. It should then slide out. Slipping into gear has nothing to do with the tranny hanging up while you try to remove it.
Old 03-22-2007, 06:42 PM
Vehicle: 2003 Ford F150
Yeah, it sounds like the input shaft is hung. You can try to seperate with a prybar. Keep the tranmission level as you apply force with the prybar.
Easy does it.
Old 03-23-2007, 03:07 PM
Thumbs up all squared
thanks for the help fellas, turns out we made a vital mistake and didn't put a jack under the motor. once we did that the trans came right off. guess that's why there was bind.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Forum Jump
