2005 shot transmission...help
So here's the situation:
2005 F150 xtra cab lariat, 6" fabtech lift, 36" tires, no modification to gear ratio. I've got 37,500 miles on the truck, no major hauling or excessive use of the truck. The "check engine" light came on and took it to Ford to be diagnosed. They say the tranny is coming apart and needs to be replaced. They say it is out of warranty and will not budge on the $3,750 to fix it.
Anybody else had similar problems? Am I wrong to be "upset" that Ford will not cover this? Any suggestions?
Originally Posted by ian51279
Yes. Suck it up & buy a new one. That's the pricw you pay to play.
A second opinion is always a good idea....thanks Chris.
I have decided that if I need a new tranny I'm not going to have Ford install it...or do any more work on my truck for that matter....anybody have any recommendations on which way to go and what tranny to put in?
Thanks for the responses guys!!!
Originally Posted by slysharky
Wow, what an intelligent reply....so I guess I'm the idiot who thinks he should get more than 37,500 out of a transmission....and only about 17,000 of that was after being lifted....not to mention it was all under normal driving conditons. "Built Ford Tough"....yeah, right! ian51279, i wish i could be as wise as you.
Originally Posted by bferrel
Sorry to hear about that. I'm actually taking mine in to get it checked while im still under warranty. I have a very slight shudder between 1st and second gear every now and then. Don't want it to get worse. Good luck with your tranny man, sucks it didn't happen 2000 miles ago.
My truck had the almost same shudder, except mine did it all the time. I had the PCM reflashed & it was gone.
