Tranny swap
Mine is an OTC, I bought it from a Mac tool dealer.
The only place I have found to get it online to show you what it is is Etoolcart.
The tool itself is intended for explorers and then you have to buy the adapters for F series.
http://www.etoolcart.com/index.asp?P...OD&ProdID=2066
http://www.etoolcart.com/index.asp?P...OD&ProdID=4104
I hope that second picture has more than what it shows I know my kit has a longer bolt and spacer pin with it.
Alan
Alan
Originally Posted by dirtyd0g
Yours is different and that is not safe at all.
Originally Posted by built54
well with my truck in the air, and the bolt for the adjuster almost all the way out, my bracket it loose, i put the clamp on it, and moved it just about 1/4", just enough to get the keyway out, there was nothing unsafe about it...
You do not have exactly the same setup i don't think there is a tool for your setup.
