"Skipping" during bluetooth playback
I'm using a droid bionic with my 2011 F150 FX4 sync system.
I get a set of 3 "skips" every minute during playback... it's repeatable. Actually it's every 45 seconds - I timed it.
Anyone else experiencing this? It also happened with my Droid 1 - 1st gen... was told by Ford that it was the phone.
Thing is... it doesn't happen with my other car using bluetooth - it's an after market stereo JVC KW-NT3HDT. Bluetooth playback is flawless.
So no, Ford... it's not the phone.
on
If the phone has wifi try turning it off
Also
Try unpairing the devices and starting from scratch........
It also could be a bluetooth data buffering issue which only the sync guyz can fix.....
Also try putting your music on an usb flash drive instead of using the phone....
Also
I've already done all that you have suggested... what I really want to know is if others are experiencing this "skipping".
I use a USB stick for music but that's got it's own problems. Usually I get deep in to my music collection then at a random time later (maybe a week) the sync system "re-discovers" the USB stick and starts over from scratch... so I lose where I was in the playback.
I think this has to do with the "programmed reset" that Ford has now openly discussed... the sync system, at least the touch screen version, goes through a reset operation every so many hours.
What a horrible design for a consumer product.
Also
Also
