97-98 -Need Stock Shock Measurement.
Having no luck finding the correct stock front shock measurement for the long T-bar models. Anyone have and old shock lying around ? I don't have mine, -I tossed them, my bad.
I would like to put this issue to rest. I have the Bilstein's and they seam to be short. I cross referenced the length with Monroe's and they are the same.
The only thing I can do now in order to verify is to compare with a stock part.
If the stock shock is the same measurement, then I'm taking the truck to the frame shop to figure out why the bushing are failing in a very short amount of time.
The front end has been checked out, it's tight - all parts have been replaced @ the dealership. Front end has been aligned/ wheels have been re-balanced.
It has to be the shocks or somethings bent, spent allot $$ trying to fix a problem I didn't have before installing these shocks.
Any help would be appreciated.
98 F150 4x4 w/trailer tow/off-road package/E40D. Build Date 7/98
Thanx
Thanx
I have a 97 4x4 offroad trailer tow with 4.6, 4R70W. It's stock. I replaced the front shocks with Monroe's that are stock replacements. I compared them with the originals and they looked the same. If you want I can take some measurements in the morning with the wheel on and off. I have had no probems for over 5 months. Let me know what measurement's you want.
Dynotech, could you do me a favor?
While you're measuring the shocks, could you send me the tire pressures from your door sticker?
I have a 97 that the previous owner put the 17" offroad wheels on and I need to know what the correct tire pressures are for the 265/70/17 tires are supposed to be.
My truck originally had 255/70/16 tires so that's what's on my door sticker....
TIA
Ted
TIA
Ted
TIA
Ted
TIA
Ted
jbrew, fwiw, i swapped the longer torsion bars in on my 03, and faced no issues w/ the standard oem length shocks. i ran the longer torsion bars cranked fully w/ this setup, and after an alignment, i faced no shock related issus. i did split cv boots on both joints, however.
Thanks, I thought maybe they would be different. Maybe the shocks are defective? Idunno - It rides awesome right after new bushings - Never lasts tho.
hey jbrew i had to get 2 new shocks for my driver side front and since i needed them on the spot i got them from napa and i was looking for the stock shock lengths on my truck so i can get all new ones from summit. and napaautoparts.com had the extended lengths, travel lengths, and compressed lengths listed with there stock replacement shocks. maybe look there.
napaautoparts.com is a dead link - wait! it opened in a "chrome" bowser. Yea, just gives me a bunch of napa servers ?
http://www.napaonline.com/masterpage...=7&SubCatId=10
This one ^^^ works. There we go, there is 3 extended length sizes 14.25, 14.35, 14.85.
I need to send this info to Bilstein when I send my shocks back if I have the wrong size. They told me on the phone and in letter that one size fits all - the 7700 series pick up. This blows, all the time and cash wasted from getting the wrong product. But the "wrong product" has to be proven first. Once I can do that, I'm definitely going after them. This is crap. But, yea, I have to prove without a doubt first.
I was thinking about just ordering replacements from the dealer. I'm not sure, I may just stop by a couple different ones and see what they list first.
Thanks Matt.
I was hoping for someone to have a old front shock laying around somewhere. That would give me some kind of reference to shoot for.
Thanks for the offer, I appreciate it!!
EDIT: If you can find a way to measure on the vehicle, let me know how you did it and I'll try the same.
just dont get your shocks from napa and you'll be good if you can find the right shocks. or at least the napa response, cuz thats what i got and my driver side rides like sh^t. the factory 16 year old shocks with just under 270000 miles ride better IMO. the new shocks are just way to mushy. but i hope you find the info you need. good luck
So now I'm down to the shock itself again
I guess the question I have now is, - What does "extended length" cover? How do they get that measurement ? Is that measured by jacking the vehicle up with the front end hanging? Or, shock length - bushing center to bushing center?
I wonder if I could buy a set of old ones from the scrap yard, just to get a measurement. I would do that, if they had them lol.
you should make 2 measurements, with the shock off the truck. for full extension, measure what the distance is from top mount to bottom mount with the shock off, and truck jacked up by the bumper or frame till tire comes off the ground. check that full extension is at least that length.
for total compression of the shock, with the truck on the ground, measure the distance between the top and bottom mounts. then subtract the distance between the bump stop and the frame. the shock must be smaller than this number when totally compressed.
Good Find! - That's definitely going on the list of things to do!
Yea , I didn't try fte. Should have, I get allot of hard to find info there.
I'm going to be using the truck to pull 1200 mile round trips w/5000 lbs @ max. I have everything right where it needs to be - as good as I'm going to get it anyway , runs and brakes great! This last detail and she's ready.
Thanks!!
Thanks!!
