About to RIZE it up
Old 02-14-2009, 02:27 PM
floorit's Avatar
About to RIZE it up
Ok guys. i should be tarting my build within the nest 2 to 3 weeks. i got most of my parts in just waiting to order tires (which should be next week). i am lifting my 07 Screw 10 inches. this is my parts list as of now.
Rize 8 inch lift
Rize 6 inch blocks and u bolts
Rize break lines
Bielsten 5100's
4 inch skyjacker AAL
Pro comp drive shaft spacer (for now, hope to get new shaft)
Skyjacker rear shocks
Yukon 4.88's front and rear
Yukon rebuld kits
37 13.50 20 interco ss m16 tires
I should be ordering the tires next week and the all and spacer should be here by the end of the week.
This is the truck that is about to get a nose bleed lol. let me know what you guys think
Old 02-14-2009, 02:36 PM
Stephen87's Avatar
where , if you dont mind me asking, did you get those rims and what size are those rims
also cant wait to see what it looks like I am just waiting till I get a better paying job to put some extra money in the bank and then bam the lift goes on, until then I am looking for some rims and tires
Old 02-14-2009, 02:37 PM
FL4X4's Avatar
dude sounds awesome I can't wait to see pics. I'm really interesting in seeing those new m16s, I haven't seen any one running a set yet.
Old 02-14-2009, 02:46 PM
floorit's Avatar
they are 20 inch kmc xd series monsters. they where on the truck when i got it
Old 02-14-2009, 05:25 PM
IDNC76's Avatar
sounds sweet
but,
why are you only going with 37's with 10 inches of lift ?
Old 02-14-2009, 05:50 PM
brianjwilson's Avatar
Originally Posted by IDNC76
sounds sweet
but,
Maybe so they fit and don't rub.
Especially since he's going with 13.5 wide tires.
Maybe so he's less likely to break CV joints if he actually uses the truck offroad.
Old 02-14-2009, 06:05 PM
floorit's Avatar
i have seen pics of 04 -08 f150's with the suspension really flexing. the rear fenders seem to have just over the same radius as a 37 inch tire. and plus i found that tire for agood price and im about spent out lol. and is there that much diffrence from a 37 to a 38 . just a half inch of ground clearance
Old 02-14-2009, 06:09 PM
06yz250f's Avatar
um... anyone w/ 8" of lift whether its a rize or 6" w/ cranked coilovers, etc 37/13.5 is what 99% of people run. cowboyup or w/e her name has 9" of lift with like a 15.5" wide tire i believe. eufhrin and cashel both have 9" (obs tho) with 15.5"s.
OP, are you sure those wheels have the correct backspacing for the lift? i would hate for you to get your truck done and them not work, they just don't seem to stick out far so thats why i am wondering.
i personally would go 38" since your going so big, but fx4life is at 10" w/ 37s and it does look good so either way can't wait to see the truck
Old 02-14-2009, 06:10 PM
4wd150's Avatar
its going to look sweet!cant wait for the pics
Old 02-14-2009, 07:13 PM
FX4life's Avatar
Even ill have 38's soon, probably around the time I get my Rize trac bars. My 37's still look brand new and i dont really want to wait another year for 38's. 10" of lift with 37's is okay, somedays i love it somedays i hate it, its all how your looking at the truck. Mainly i think its the width of the tires.
Old 02-14-2009, 07:43 PM
tlt008's Avatar
I was wondering the same thing about the backspacing on those monsters dude....
I know aflores has a 12" Rize and runs some whells w/ a 6" bs but they rub on the suspension. I'm going with a 20x10" w/ 4.5" bs because it seems like that is the perfect combo. I'll also be running 38x15.5's though on 10.5"/11" of lift.
You might want to invest in other wheels w/ less bs or buy a set of spacers for the wheels if your budget is tight.
Old 02-14-2009, 07:48 PM
floorit's Avatar
is there any way you can mesure with the wheels on the truck or do you have to take them off?
edit. i just went out side and looked at the with a tape. i think they ar 20x20's if so they have a 5.03 backspace. they have 305 55 20 nittos on them and they stick out about a inch to a inch and a half out passed the fender flair.
Old 02-14-2009, 07:56 PM
tlt008's Avatar
If they are 20x10's they should have 5.03" bs and you should be ok. If they are 20x9's then the bs should be 5.71" and you'll have problems most likely. I don't know how you'd go about measuring the width since that measurement is taken from the insides of the beads.
Old 02-14-2009, 07:58 PM
tlt008's Avatar
I'm guessing by the looks of it they are the 20x9's w/ 5.71" bs. I'm not positive though.
Old 02-14-2009, 08:05 PM
minimonster17's Avatar
make sure to extend the rear driveshaft after you install the lift. dirtbound has had his fall out on the road.
the spacer is not going to be enough. you need like 3'' more driveshaft w/ 8'' of lift. as crazy as it sounds, i needed 1 1/4'' w/ only 6'' of suspension lift. a 1'' spacer is not going to cut it for 8'' of suspension lift, trust me. your transfer case is gonna leak, and you run the risk of stripping out the extension housing, driveshaft falling out on the highway, etc. that driveshaft slip yoke is only supposed to stick out 1 1/4'' out of the extension housing.
find a local shop that extends driveshafts. they cut the ends off of your stock driveshaft, and weld a new, longer piece of pipe in the middle, and rebalance it. i paid $198 out the door for my extended rear driveshaft w/ new u-joints. i pulled and reinstalled it myself.
also, for the record, i think cashel is running 38x 14.50's.
Quick Reply: About to RIZE it up
