I hit a HUGE bump
Old 08-12-2008, 08:30 PM
Camarothatcould's Avatar
I hit a HUGE bump
Parking lot was completely empty last night so instead of going all the way out to the street, I cut through the parking lot. 35-40 MPH I blindly hit a center divider. I know I got air and everything in the back of my truck hit the roof. I went back today and looked at the divider and it was about 7 inches high and 2 1/2 foot wide. I havent gotten under my truck to inspect, but what may have been damaged???
98 expy 4x4
Old 08-12-2008, 08:40 PM
scott1981's Avatar
Dude, get under the truck and look. You could have damaged any number of things
Old 08-12-2008, 08:59 PM
glcash's Avatar
x2^^^^^^^^
zambonimaxx's Avatar
Main thing you should inspect is that your rims are still even holding air in the tires! I bent my rim on a dang speed-bump. Check that, and have your alignment checked! Good Luck man
~Phil
"Semper Fi"
Old 08-12-2008, 09:05 PM
minimonster17's Avatar
let's see, you could have bent a crossmember (torsion bars, transmission), punctured the gas tank, gouged the oil pan, there's no way to know until you take a look.
Old 08-12-2008, 09:27 PM
4.2trimble's Avatar
my be is that you damaged alot more than you might think. thats a high bump thats usually not very friendly.
Ball Joints, CV Shafts, Torsion Bars, Idler Arms, sway bar endlinks are probably toast, oil pan, trans. pan, cracked a wheel, cracked a radiator, broke an engine mount.
With no lift thats a big bump at any speed.
I wouldnt take my truck over it a 10 much less 30-40
Old 08-12-2008, 09:28 PM
99and04f150's Avatar
good lord man......... I saw a focus hit a center divider once......needless to say it did not get air...it got crushed.... X2 on what everyone else is saying.... you are lucky you even got the thing home esp if you were really going 35-40 mph..... good luck...let us know what is FUBAR
Old 08-12-2008, 09:29 PM
All tires have air and no rims look bent.
Bump stops definately hit and hit hard. . .
Old 08-12-2008, 09:31 PM
scott1981's Avatar
BFT man, your lucky
Old 08-12-2008, 09:32 PM
Old 08-12-2008, 09:34 PM
4.2trimble's Avatar
go take a pic of the sway bar end link. On the front suspension. im intrested on how they would have help up. ive broken 2 sets on my F150 3 sets on my Ranger and 1 on my Explorer
and the driver side one looks dented or bent
Old 08-12-2008, 09:41 PM
I'm not going to hobble outsite again tonight(broken leg n ankle). I'll be outside again tomorrow so I will get more pics tomorrow. I shook everything from the end links to the a-arms and everything feels tight. Let me know if you guys want pics of anything else, I'll get them tomorrow. . .
Old 08-12-2008, 09:44 PM
Originally Posted by scott1981
BFT man, your lucky
Big Fawking Tires???
Old 08-12-2008, 09:46 PM
be fawking thankful... i guess.
Quick Reply: I hit a HUGE bump
