Noob ? : How to measure my lift
Geeez take it easy on the noob! I knew it was a Fabtech lift, just wanted to know how to measure it. Anyways..
2007 Supercrew F150
20" Rims
35x12.5 Toyo Open Country M/T
Fabtech 6" (?) Coil Over lift w/o the Dirt Logic upgrade
Rear Leveling Blocks (Haven't measured them yet.)
Pics of BIG Red II
https://www.f150online.com/galleries...cfm?gnum=11804
I suspect it is measured from the Bottom bolt to the top bolt on the front crossmember, but want to make sure.
Thanks,
Jeff
2007 Supercrew F150
20" Rims
Pics of BIG Red II
Thanks,
Jeff
Fabtech 6" is the only fabtech lift (i think) for the 04+ F150's. However with the coilovers you can crank them to get an extra couple of inches!
It kinda hard to measure a lift, usually you would measure the lift from the middle of the fender well then measure there after you lift it and before you put on the tires.
The kits is a 6" Lift but it can be adjusted to 7-8 just by cranking them coilovers! Hope that helps
yes it does need a bath. It's been raining for about 10 days now, and I live out on a country dirt road. But I am off for the next 7 days, and my girl will be learning how to help me detail it out.
Thanks Trimble, I'll have to take a closer look at the coilovers to see if they are cranked up.
