can i take out the front drive shaft
i was wonder would anything go wrong ie: leak transfer case fluid or burn up any thing if i unbolted the front drive shaft and took it out to save gas on this trip im about to take its about an 10 hour trip both ways and with out the whole front end turning i figured i would save alot of gas
Get the gears you need instead of removing the front drive shaft. Removing the drive shaft will not help with gas mileage. If a rear U joint goes bad then you can always come home in front wheel drive. hehehehehehe!!! I sure hope you have gears other than stock.
No. Engine on in 2wd, nothing in the front should turn. Not the axle and not the driveshaft. As soon as you shut off the engine, the axles should turn and the driveshaft should turn, simply because the IWE's are locked and exngaged with the axles. Only the 97-03 had always engaged axles. The driveshaft would not turn in 2wd as the front diff was disengaged. There is no engage/disengage of the front diff on the o4 up.
