Would this setup work?
Just wondering if this setup would work because i am not very experienced with backspacing and offsets. I want to get a 6" procomp suspension, and the 3" PA body lift. would that be enough to clear 38x15.50 R20's? Im not set on wheels yet but i am thinking moto metal.. What offset and backspacing should i look for? Thanks
I am not the expert on Back spacing, I'd wait til Wandell to chime in on that. He seems to know his stuff in that department. But just curious(sp?) why Pro-Comp? You can get FabTech for just a little bit more $$$ and wont have that huge Pro-Comp spacer (assuming your getting the stage 1) Fabtech has some nicer features and a better looking front cross-member. Of course this is all according to opinion and budget. I got my Fabtech delivered for $1400 or so and thats for a 4x4.
P.S. I'm not sure, but sound like the setup you want would work, with some trimming and proper BS. Good luck
Sounds like it would work... but like I said other guys will chime in tomorrow and lead you in the right direction for tires and wheels. As for suspension, I would highly suggest saving the extra couple hundred and buying the FabTech. Especially if you are 4x4 and even more so if you plan to do any off-roading.
