Ball joint questions.
I've got an 04 F150 with 90,000 miles on it. It's time to change my ball joints, and I can't find any moog replacement ball joints. Advanced Auto Parts, says that there is no aftermarket parts available yet, and my online searches are only giving me 97-04 choices which I assume is the old body style 04.
Has anyone changed theirs? and do you have any leads on where I'd get some? I'm looking for the Moog upper control arm, and the lower's.
TC total chaos arms do not use ball joints.
heres the run down the only way to replace the upper ball joint is with a whole new arm, the lowers everyone should be stocking by now and the go in the same as any other ball joint nothing special just a press tool. I had moog and I felt they were crap the boots riped not 6 months in and then they just let the grease go everywhere. I went back to ford BJs and havnt had a problem
for the 04+ here you go from advance web site. You have to buy the hole assembly. Man I looked at these awhile back and I thought they were around $80, guess they have went up alittle.
http://www.partsamerica.com/ProductD...tNumber=FA4117
Originally Posted by Flyboy60
OMG - those UCA are hot!!! SEX on wheels.
What website to check those out at?
or go to www.chaosfab.com to view there product line.
Well on my 98, I replaced with Moog, but only because they had the built in grease fitting. I talked to my Ford dealer, and they still don't have grease fittings in them. I've always used grease gun needles and put grease in my OEM joints, but that doesn't always get up into the ball all that great.
Besides some of the other options above,(which are great, but I'm running this truck stock) what other manufacturers has anyone had luck with?
