How much oil to use in SuperCrew
I have a 2001 SuperCrew and I'm confused on how many quarts of oil it should use.
Walmart puts in 5 1/2 qt and leaves the other half in a plastic bag on the seat.
So I went somewhere else and he said I had 1/2 qt TO MUCH in it !!
Then I go to another Walmart and they tell me I'm 1/2 qt low.
What the heck is going on?
Do I need 5 qts 5 1/2 or 6? And why would service depts not agree on the amount of oil it should hold?
Thank you
Thank you
From what I was told the levels they list in the owner's manual is an "average" across the production line of that vechile type and specs. Because I ran into the same problem where the dealership changed my oil and said they added 7 quarts instead of the six listed. When I asked why they did this and that is what I was told. Not quite sure what it meant then or yet still today.
I used to work part time at a well known fast lube place and their computer system would tell you have much oil to pour in depending on what type of vehicle you had. A lot of times it would just barely be above the min line and if the customer wanted it at the full line he'd be charged for another Qt of oil.
I felt it was just another way to get a buck. I quit after a few months cause I felt alittle quilty charging senior lady's over 25 bucks just to change their wiper's and the fact I was ready to kick some punk *** kids for the way they worked.
The company loved it, just be glad they're not in the tire business.
The 97-03 5.4 takes 6 quarts. Period. End of discussion. If your local shop is charging you for 7 quarts then they are screwing you, and if they are only giving you 5 quarts then you are running a quart low.
Oil
The manuals do not spec. an average amount of oil. My '97 4.6L XLT always took 6qts. with a filter change which is the only way I have ever changed the oil. My '04 5.4L calls for 7 quarts w/filter. Guess what? 7 quarts was right. Follow the manual, ensure the oil is adequately drained ( ie truck is level @oil change) and make sure no leaks after. A relative had a problem where a filter was changed but the neoprene seal from the old one 'stuck' to the sealing surface of the engine. This occurred on a Toyota and the oil chg. was by Jiff....e. Anyways, the truck dumped all the oil in less than a 1/2 mile from them. Luckily, he shut it down immediately and the problem was only an inconvenience.
Originally Posted by theantiriced
I put 6.5 quarts in my truck. I know the book says 6 qts, but that only brings me up to the minimum level on my dipstick.
-Craig
-Craig
Originally Posted by 2001Screw4x4
You either have the wrong dipstick or you are not inserting it all the way. 6 quarts is what the 97-03 5.4 takes, and that will take it to the "full" line, not the minimum line on the stick.
I beg to differ. You can find dozens of board members here who will tell you that 6.0 quarts will show from anywhere from 1/3 to 2/3 of the distance between "full" and "add a quart" on the dipstick of a 5.4 or 4.6, including me.
