2005 SCREW new Rancho QL struts .. still rake
The Rancho rep hangs out in the Suspension section very often here, he would be able to tell you if those are the right ones. I got the wrong ones for my truck (even though their website told me they were the right ones) and the rep here hooked me up and took care of me.
Are you the only owner? Are you sure there are no lift blocks in the back that may have been added for the tires? I bought a truck once and it was always low in the rear, turns out the P/O put on lowering shackles. Took me a long time to figure out they weren't the stock ones.
If you look at the gap from the top of the tire to the bottom of the fender...you'll see the space is shorter in the front compared to the back...Might be about an inch.
But the rake was definitely worse prior to the Rancho QLs...so I'm happy with the result.
