how to polish something?
I like this pic,it kinda shows u whats involved.First off make sure u have a decent respirator.(Lots of black tasty dust)I used a dremel with some 120 grit flap wheels to get down the initial roughness,then to 220 grit flap wheel.From that point on i worked through the grits fom 400,600 by hand.I then used a spray bottle and wetsanded at 800 grit.At this point i started to actuallly polish the metal with white rouge compound(they can be found in Home Depot,Looks like giant lipstick tubes,popup style).To apply and polish with the rouge i used an electric drill with buffing pads found at home depot also.You'll have to go back on spots sometimes by hand but dont be discouraged.Final polish can be done with some mothers.Its dirty and tries your patience but the end results are rewarding.Total time to do the nose of my blower, the ribs and base was about 20 hours for me.I did a little bit here and there.I had the truck down over the winter.
Originally posted by 20"svt
this link should help you out
http://www.caswellplating.com/buffs/buffman.htm#tricks
--Joe
hyvoltage....
hey bud, if you dont mind... could you kinda give me a run down on step by step and what exact materials I will need?
looks like I will need a dremil and a polish end for a drill.... any other tools....???
i was gonna say email me... but might as well put it on here for everyone to see
thanks alot!!!
thanks alot!!!
