XM Antenna Location
Old 11-19-2010, 02:54 PM
XM Antenna Location
Right now I've got a Pioneer GEX P920XM XM SAT radio tuner... I've got the antenna mounted about 8" on the right hand side of the roof, just above the passenger seat. I notice when I go by tall buildings, the radio cuts out. Should I consider moving it to the other side? Or is that just a waste of time and won't improve anything?
It only happens when I'm close to tall buildings. Every place else I'm fine... even under large overpasses and in my garage it works perfectly fine. Or is this just the nature of the beast?
Old 11-19-2010, 08:03 PM
jetech00001's Avatar
manual150 i don't understand how could you hit anything with that tinny xm antenna. i installed an aftermarket xm antenna on a truck i mounted it just fwd of the third brake light and ran the cable under the lens cover and used sealant never had a leak as the cable is very thin.
Old 11-20-2010, 10:38 AM
Could you give me an idea for an aftermarket antenna that will work with this GEX?
Old 11-20-2010, 05:24 PM
i would give a call to cruchfield 1 888 955-6000 or check out any aftermarket stereo places in your area they would be the ones that would know for sure.
Old 11-20-2010, 08:38 PM
Gtullous's Avatar
mines inside the truck up next to the little sensor on dash.....
Old 11-20-2010, 11:30 PM
ManualF150 i miss read your post yes you will lose your signal if a tall building or freeway over-pass blocks your signal mine does the same thing you need a clear path to the satellite and i believe in some cities the have repeaters and i apologize on miss reading your post.
Old 11-21-2010, 08:44 PM
Don't sweat it man... we are all human!
As far as signal strength, I think where the antenna is likely just fine... it's just those stupid concrete/rebar buildings...
Old 11-23-2010, 02:21 PM
Ponyboy24's Avatar
I installed my Sirius antenna under the dash. The antenna is on the metal bracket just underneath the coin tray on the top of the dashboard as close to the windshield as I could get it. It works fine and I haven't had any problems at all. You could consider that as an option.
Old 12-29-2010, 09:56 PM
BullyDogJason's Avatar
Former Sponsor
i placed mine right above center of the windshield. was the easiest location to run it to.
id only loose signal when i was on the north side of a tall building
Quick Reply: XM Antenna Location
