06 F-150 OEM Head Unit / OEM Sirius Satellite Radio
Hello All,
As the post title says, I have a 2006 Ford F-150, SuperCrew, with the factory installed OEM Head Unit (Not the 6-CD, just a single CD) and factory installed OEM Sirius Satellite Radio. When I press the AUX button, I get SAT1, SAT2, and SAT3.
My question is, and I'm sure it's been asked before, but I haven't been able to find an answer here, is it possible to have a Mini-headphone jack added and switch over to the AUX input without switching over to the Sirius Satellite Radio receiver?
I would like to implement my Sandisk Sansa (MP3 Player) into a hardwired port, but I would also like to have the Sirius Satellite Radio functionality as well. Is there a way to have a 4th input?
Thanks!
Thanks!
Hmm...I was looking for a line in harness somewhere...however, I do know that my system is not one with an audiophile.
I'll have to take my radio out and see what it looks like on the backend to see if there is an extra input available. Perhaps if I do buy a line in for the aux, it'll automatically detect a 4th input (one can hope anyway). If not, I'll start looking for the 06/07 6CD w/ Audiophile head unit.
Thank you.
Thank you.
In case this helps any Ford Technicians or other people out there, here's my current Radio part number:
6L3T-18C869-AC - Head Unit
6L3T-18C963-AE - Sirius Satellite Radio Module Box
If someone has the '07 setup, w/ Factory Sirius Satellite Radio & Aux Kit, could you see if you have a special harness that "splits" the signal?
I looked at the '07 radio via Ebay and it doesn't look any different than what I currently have (other than the 6CD In-Dash changer / MP3 capability).
Thanks!
Thanks!
Originally Posted by jgonza5
Yes, I knew about the Ford TripTunes, but I do not want to use FM Modulation for sound -- not after hearing a true connection with my Sirius receiver in this truck.
I spoke with someone from a Ford dealer who in turn spoke with someone who is their accessory guy that works for Ford (so they tell me), and he said that he wasn't familiar with how the 07 F-150's were wired and that he thought the Auxiliary was a part of the 07 wiring harness already built in (meaning wire splices done at the factory).
Neither he or the guy I spoke with said that they have any wiring schematics on how the stuff is tied in. I'm tempted just to buy an 07 Auxiliary Tray, the other part mentioned to connect to the radio, and figuring out what wire(s) to use (if any) to wire the sucker in.
If someone has a 2007 F-150 with the Auxiliary Jack from the factory, would you mind taking some pictures and posting the connection so that we can all see how it looks on the radio?
I've seen an what looks to be an OEM harness that comes off of what looks like the Audiophile port on the rear of the 2007 F-150, but that was through crutchfield's web site.
Thanks!
Thanks!
I looked at the wiring diagram off the Ford Service Manual DVD for 2006-2007 Ford vehicles, and apparently, the wiring diagram only shows an extra harness attached to the main harness. I did not see where the left and right channels are attached, but my guess is that it is using the same cd changer port on the rear of the radio, but it is somehow tied in via a T harness or some other means to split the signal when on different modes.
Have you got a way to post the page with that diagram. I have a cd manual for my 2006 but I guess they didn't start the aux in tray till 07. If not, can you try to email it to me?? tmd9707@charter.net thanks...
Well, let's see here. Apparently, I found something by scanning through the wiring diagrams again, so, I'll attempt to post a link to the connections of the Audio Input jack (at least it shows what the connectors are anyway since it won't load it from this page)
NOTE: Wiring schematics
wiring-diagram-audioport.tif
NOTE: Service instructions on where it is located. The part mentioned, 14401 is the main wiring harness.
415-00-1.pdf
Hopefully this helps you out
NOTE: You may need to right click on the links, and then select Save Target As. Although each should be viewable in the browser, I was unable to view the TIF image in the browser.
415-00-1.pdf
Shrapnel. I was having the same problem with my Aux input and the same truck. Hoping you still have the pictures or pdf around because the link doesn't seem to be working anymore. I would like to tap into the Aux input through the Sirius XM that I guess was factory installed. I can't seem to locate where the unit is mounted. Must be tucked away somwhere.
Thanks!!
Thanks!!
