1 ton F150 Build , tons of pictures
Old 12-25-2015, 07:23 PM
rclark12's Avatar
I figured Id throw up my 1 ton f150 project. I did most of this a few months back and this project will probably never end. Figure for now Ill try to get this thread up to speed.
Started with a 300 dollar f150 with no drive train but body was in great shape
Cleaning up everything, paint, and a whole lot of redneck ingenuity to get the cab off
In the mean time I started cleaning up a dana60 I had
Found an ext cab long bed 2x4 f250 with a 351w, blown e4od with a good frame for 500 bucks. Using the frame, engine and wiring harness
e40d out
c6 in and frame cleaned up
And back to my sketchy cab swap
I am not a big long bed fan so time to shorten her up
Old 12-25-2015, 07:28 PM
rclark12's Avatar
Found some 42x15x15 tires
Mock up
TTB salute
Its like Christmas
swapped on 3/4 chevy brakes
Old 12-25-2015, 07:49 PM
rclark12's Avatar
heavily over built leaf spring hanger
Finally
Old 12-25-2015, 07:58 PM
rclark12's Avatar
Unfortunately first mud bog I found out the hard way that my front shaft was too short for amount of travel and a threw it into my wiring harness. Of course I had my foot to the floor so it spirled the harness up like spaghetti
Old 12-25-2015, 08:08 PM
rclark12's Avatar
Back rolling again
Trucksgonewild upstate NY
Old 12-25-2015, 08:12 PM
rclark12's Avatar
And finally up to speed, sitting in the drive way with full drive train out. 351w had no oil pressure. Wound up buying a roller 351w that Im cleaning up now. Just bought a divorced case too.
Old 12-25-2015, 08:22 PM
Roadie's Avatar
I admire your energy!
Old 12-25-2015, 10:02 PM
Very cool!
I like your redneck ingenuity.
Old 12-26-2015, 02:14 PM
rclark12's Avatar
thanks guys , I'll keep the pictures coming as I work on it slowly .
Have the roller 351w in garage I'm trying to get ready for paint and picked up some 1.7 roller rockets . Keeping an eye out for some gt40 cobra or lightning heads but due to money I'll probably end up using the e7's
Old 12-26-2015, 03:02 PM
jayber's Avatar
BadAss
Old 01-01-2016, 12:09 AM
adrianspeeder's Avatar
Nice! Which computer are you using to be happy with the C6?
Adrianspeeder
Old 01-04-2016, 10:14 AM
rclark12's Avatar
it still has the 93 f250 sd e4od computer. I pulled the nuetral saftey switch off of the e4od, put it in nuetral and zip tied it to the frame rail. The c6 only needs vacuum to run fine, I dont even have the kick down cable hooked up and it operates with no issues. I am sorta keeping an eye out for a 351w manual maf obd1 computer though.
Old 01-04-2016, 10:36 AM
WoodsTruck's Avatar
While you are throwing pictures up, got any more of the green Baja with the body lift? I did that 20 years ago and sold the car.
Old 01-04-2016, 02:55 PM
Solid. I didn't know if it would trip a check engine light. I don't have that computer, but got you covered if you ever swap to a 460.
Adrianspeeder
Old 01-04-2016, 10:56 PM
rclark12's Avatar
Its my buddys baja I can get pictures.
As for the 460 swap I was on the fence for a while if I was going to go big block or keep small block, and fuel injected vs carb. For now it was just more cost effective to stay 351w and speed density and since I couldnt swing any big power mods speed density and small block aren't really holding me back to much. Roller 351w with 1.7 roller rockers, exhaust and some freshing up should be an imporvement from what I had.
Anyone know if an F2TE-A3A injector from a 95 351w would be an EV1 injector? Im looking for rebuild kits while I have mine out but am not having good luck finding good info.
Im pretty damn sure I just need the EV1 injector rebuild kits I am seeing but wouldnt hurt to know thats correct
Quick Reply: 1 ton F150 Build , tons of pictures
