is it worth it?
is it worth it?
Hi everyone I'm looking for some honest advice,
I purchased my truck about a month ago and discovered that the transmission is starting to slip and shutter.
Its the E40D trans and the 5.0L V8.
I was quoted $2000 for a complete trans rebuild so I'm wondering is it worth it or should I cut my loses and buy another truck?
Thanks in advance.
Thanks in advance.
You don't need a rebuild till it stops working.
http://www.fullsizebronco.com/forum/...d.php?t=122096
i give it 6 months or less had the same engine and trans in my 93 i just junk automatics i cant stand them i only buy stickshift id rather replace a clutch for $120 then a $2000 trans
in a little over 2 years i blew 6 trannys in 2 trucks that were auto and 2 of them were brand new
ive never burnt a clutch or blew a manual trans n i beat the snot out of my trucks and tow upto 3 tons at one time
Thanks in advance.
Thanks in advance.
The E4OD is a good transmission. Stock they served me well. If you take it to a reputable shop and have rebuilt, it will last for quite a while. My E4 has had considerable custom work done to it and its tuff as nails. The p.o. only spent $1300 to have it done. Mind you it shifts hard under substantial throttle (cushion plates removed in favor of more clutches) but I was able to get rubber into third.
your going sas? Id love to see that build thread there is nothing I want more in an f150 then a solid axle I think thats the best. Are you going 4x4 too?
