Motor swap.
Motor swap.
Will a 90 and a 94 inline six be a direct swap? Don't even have the motor yet (if you are reading this stewy, I'm workin on it), but I want to make sure everything will basically be plug and play. Will have both wiring harness' in case that is an issue.
I'm gunna be lookin for a mazdog soon so if anyone has one
No hurry russo. The engine is out and complete including the harness,computer, rad,fan,shroud, starter,aiirbox,etc. The cab was off the truck so i just cut the frame off on either side of the engine mounts and left it complete. Saved the driveshaft, rear view mirror and horns like you asked too. oh and i lied to ya. i told you it had 50 k on it. The odometer actually said 55 k. sorry about that. but what's 5k on an I6? not much! And what's a mazdog?
Mazda M5OD transmission. No I don't want your 2wd one.
And I just found this.. https://www.f150online.com/forums/pr...wd-vs-2wd.html
It's a good thing I talked you out of the swap how long ago.. hahah
Funny stuff though.
Funny stuff though.
While I'm here, and steve may chime in, Can I pull the A/C, all in one unit of course (even though I have the equipment I don't feel the need to attempt a discharge) Without affecting anything else, air/heat wise?
Better yet, if stewy hasn't annihilated the parts truck can I just drop that A/C stuff in.
Edit for coming up with more dumb questions.
If the A/C is drained, could the pump then be used as a idler pulley I guess you could call it, meaning would it do the same as a delete pulley or would something go wrong there
When I evacuated the a/c it still had a full charge in it. But if I'm not mistaken your 1990 has an R-12 system. And I snapped off the lines going into the condenser soo.. roll down your windows. I did read one of Steve's posts recently about getting the system out without evacuating it. Unfortunately that's not the way I went about it.
