ecmb
You didn't say whether you have 1 or 2 tanks, it may make a difference. If you have 2 does either of the pumps work?
You're looking for the Engine Compartment Fuse Box on top of the LF wheel well.
On a 96 the fuel pump relay runs off of fuse #16 (20a fuse middle row 4th from bottom) the 95 may or may not be the same. The square box just to its right is the fuel pump relay which you should also need to check.
If both of those are OK you need to trace the circuit point by point till you find where you are not getting continuity. This includes the inertia fuel shutoff and the selector switch (if you have one) and all the wiring in between.
The bad news is that fuses don't just blow on their own. If the fuse is popped you have a short somewhere and you need to find it.
How did you check the relay? Is it clicking when you first turn the ignition to "on"?
Check the inertia switch to see if it has tripped and to see if there is continuity across the switch.
Do you have a tank selector switch? If so flip it to the other position. Does the other pump work? Do you have continuity across the switch?
on
Let's start from the beginning: tell us EXACTLY what the truck is & isn't doing, how long it's been this way, miles, mods, repairs, damage, options, trim level, engine, trans, 2- or 4WD, 1 or 2 tanks... ALL the details. If you don't know, read this caption:
We can't answer your questions until you answer ours, so go back thru the thread & make sure you answer them all.
