Strong coolant smell?!?!?!?
yes, just another problem this truck had when i bought it, and i am just getting around to fixing them. The truck has always had a stron smell of antifreeze when running, inside and out. I know it's leaking, but i haven't found where yet. Has anyone else had a similar problem? And if so, where was your leak?
Heater Core?
My truck had a bad heater core and would fog up the windsheild when I turned the heater on. Also you could smell it.
If your not seeing anything on the ground then its probably the heater core.
Its really easy to fix on F-150's. Its behind the glove box. Not too expensive. About 50-70 bucks for a real FORD core.
dave
dave
On mine they're right above the oil pan. They look like the end caps for a small poster tube. I don't knoe how many there are, and since it cold here, 60's, I ain't getin all dressed up to crawl around and find out.
Actually I have a six and you have an eight so it wouldn't matter anyway.
Hey 1depd, 60's is cold???? LOL, i was out in the garage, non heated or insulated, with a jacket on, in weather in the teens, ripping the door panels off the truck to fix a window, lol. I'd love 60's here so i could really work on my truck. And all dressed up, man people here would be near naked in weather like that...well not really, but that is tank top or short sleeve and shorts weather here.
Yeah, i'll have to check the pump, that sounds like it could be the problem.
I love the 5.0's!!!!
stong coolant smell
two thing i would look for is the water pump leaking out of the small hole on the bottom which is just like a check valve and when the go bad they leak while running. also look for coolant leaking either down the firewall by ur heater core or onto the passanger floor board that's a good sign of a bad heater core
