2001 F150 speed sensor pulse and reverse wire
Old 01-21-2007, 03:03 PM
brahmus's Avatar
I did a search and most of what I'm finding is 04+ guys talking about this. Can anyone confirm the speed sensor wire and the reverse wire I need to tap into for my avic n1 ? I have naviation on it, is the speed sensor wire a must? It seems to work ok without it but I'm guessing it may be more accurate with it. I'm thinking I can use the one that was used for the factory radio? Thanks guys!
Old 01-24-2007, 08:11 AM
jlcotney's Avatar
Did your stock radio have speed sensitive volume? If so you can hook up to the speed wire found in the second factory wiring harness that you are not using when you hooked everything for you aftermarket system up. Use the gray/pink wire in the second harness. Check out the diagram below. Hope this helps.
Old 01-24-2007, 09:15 AM
brahmus's Avatar
Ya, it looks like I'll beable to do that. Just need to confirm which wire it is. I can't access that link.
Old 01-24-2007, 02:13 PM
6spdcoupe's Avatar
Could also try Gray/Black at the radio harness. Worked for me a few times.
Reverse wire is really only needed if your using a backup camera. If you have one, let me know and Ill look up the color.
Old 01-24-2007, 02:30 PM
brahmus's Avatar
I think that is the speed wire I'll need. Yes I do have a reverse camera!
Old 01-24-2007, 02:35 PM
6spdcoupe's Avatar
ahhh ok, Ill check a bit later in the day for ya then. If it cant wait...taillights are always an option....
Old 01-24-2007, 04:00 PM
brahmus's Avatar
No hurry.. thanks man.
Old 01-25-2007, 07:55 AM
jlcotney's Avatar
Check my post again. It's pin 9 in the second harness. It should be a gray/pink wire.
Old 01-26-2007, 12:00 AM
6spdcoupe's Avatar
May wanna check both with a meter. Three sources tell me what I posted above. Been awhile since I did one so I cannot recollect.
Didnt find much on the reverse though. Sorry.
Quick Reply: 2001 F150 speed sensor pulse and reverse wire
