50" Curved Light Bar Brackets for 04-08 F150
I recently purchased a 50 inch LED curved CREE light bar. I need suggestions on where can I get some decent looking but sleek type brackets which is flushed between the roof and windshield or just a few inches higher from the windshield. anything more than 2inches, I won't be able to get in my garage. My truck is not lifted, just a leveling kit(front) in case you're wondering. Most of the brackets I have seen are for the 2009 and up. Hardly for the 2004-2008 models.
Thanks guys!
Thanks guys!
Thanks everyone and have a great weekend!
ABOVE: OLB brackets with a 50" curve light bar (NOT the correct brackets). BELOW: SoCal Super trucks 50" curve light bar (very strong and stable at high speeds. And looks a lot better than the OLB. The OLB brackets were forced to be bolted onto the light bar, adding tension to the windshield and door seal. And it was not fully flushed with the windshield and roof and can be seen wobble side to side while driving in the freeway. As for the SoCal brackets, I have added black silicone sealant around the brackets to prevent from leaks when it rains.
The LED light bar at the bottom is a 30" with Rigid Industries 30" mounts.
How did you run the wiring and where did you put the switch at for the roof mounted light? Also with the black trim piece that runs from the windshield up and across the roof, did you just drill through that to bolt the mount or did you cut the section off where the mount fits? Nice looking truck BTW.
