secondary plugin pin out anyone?
after searching i cant seem to find the pin out for the secondary plugin (04 new body style base radio with aux button but no aux port). if anyone can post it id greatly appreciate it.
heres a pic showing both but im interested in the left one:
closeup on the plugin in question:
thanks.
thanks.
Take a look at this thread, It shows the pinout of the connector that carries the audio from the CD player to the radio. I believe that the ASYS signal is used to control the CD player. But you should do some further study to confirm that. Link: http://www.explorerforum.com/forums/...d.php?t=266178
just found this:
"So i know im a lottle late to the game...but i found a 5 dollar fix for this. Get an aux cord with the headphone jacks. Take off the small plug on the back of the stereo. Cut off 1 jack and hook the wires up to pins 6,7,8 and 14. I left the plug off. Didn't have the time or patience to wire it into the factory harness. Works just fine and didnt need the 150 dollar hookup. The cord had 3 wires instead of 4 so i added a splitter. Didnt seem to matter what wires went to what pin so i ran the splitter to 8 and 14. Hope this helps. If your looking at the back of the stereo, last 3 pins on the top row are 6,7,8 respectively. 14 is right under 7. Tried to load a diagram but cant. Its at www.justanswer.com"
from here:
http://www.fordf150.net/forums/viewtopic.php?t=50036
ill have to try this out when i get some free time. seems to match the pinout i posted above. i do foresee a problem though with it going into aux mode without an external power source to trigger it unless the radio registers it being active if the device is playing and sending a signal. guess well see.
from here:
