P0420 Cut off cats?
Since you failed to provide engine size, I can't give you specific info. ALWAYS give this info if you want help for a specific problem.
The Simple Answer: ~ Replace your converter.
Here's how it works, in case anyone's interested.
DTCs
P0420 Catalyst Efficiency below Threshold Bank 1
P0430 Catalyst Efficiency below Threshold Bank 2
Monitor Execution
Once per Driving Cycle. (On MIL equipped vehicles this test must be failed three times before the MIL light is switched on.)
Monitor Sequence
The following tests must be complete before the Catalyst Monitor can run:
♠ HO2S monitor tests complete and no DTCs
♠ No Fuel Trim DTCs
♠ EGR Monitor Complete
♠ No Misfire DTCs
♠ No SAIR (Secondary Air Pump) stuck on DTCs (where fitted.)
It should be noted that faulty HO2S sensors do not produce the DTCs P0420 and P0430. The sensors must all be tested and shown to be reliable before the Catalyst Monitor can be called by the Executive.
Sensors OK
The following sensors have been tested and shown to be good before this monitor can be run:
♠ HO2S - Heated Oxygen Sensors
♠ ECT - Engine Coolant Sensor (Sub-in CHT where applicable)
♠ IAT - Inlet Air Temperature
♠ MAF - Mass Air Flow Sensor
♠ TPS - Throttle Position Sensor
♠ VSS - Vehicle Speed Sensor
♠ CKP - CranKshaft Position sensor.
DRIVEABILITY CONCERNS
None. With no MIL light if a catalyst has failed the owner will be unaware of it until the MOT emissions test. On the 24V, one good catalyst and one failing one may be borderline on emissions. Depending on the efficiency of the Fuel Trims, the spark plugs and the INJectors it may be possible for the 24V to squeak through the emissions test with two failing catalysts, although performance of the engine will be poor - running smoothly but well down on power. On the 16V DOHC engines with one catalyst this is less likely.
CATALYST RATTLE
Symptoms were a rattling from the affected catalyst. If the catalyst brick had moved, this could cause a restriction in exhaust gas flow. Symptoms for that, in addition to the rattling, was a marked loss in engine power and perhaps a whistling noise. EGR pipes could also be dislodged by the increase in exhaust pressure.
Replacement catalysts have proved to be more durable, but their service life may be perhaps six years.
DTCs
Monitor Execution
Monitor Sequence
♠ No Fuel Trim DTCs
♠ No Misfire DTCs
Sensors OK
CATALYST RATTLE
Oh I need to add. I have a K&N CAI on this for about 6 months. Code has been coming on for a month. I told bill at PHP about the CAI, so i figured the gryphon would correct that anyway. Could this cause the code? I have heard about it causing a lean condition, but isnt that a different code? Its also got a SI/DO Flowmaster 40 muffler.
