2001 F150 SC with Superchip help needed
Well, after putting 211,xxx miles on my 2001 SuperCrew it finally happened. I need to take my baby to a Ford dealer because of starting issues.
Here's the problem, I need to remove the "superchip" from the PCM (I think) before taking it in but, I don't have the installation instructions and it's been 12 years since installing it. I can't remember where the heck it is located so I can pull the chip. Anyone out there have a copy of the instructions or can tell me where to start looking?
Thanks in advance.
Ron
Thanks in advance.
Ron
Come on guys,
glc, it's a chip not a programmer and I know it plugs directly into the PCM on a 2001 F150.
Roadie, I want to know where the PCM is located on my 2001 F150. It's been 14 years since I installed it and at the age of 73, I don't remember back that far for piddle things.
I wouldn't have to ask but the program on the Service CD, I have for my truck, quick working after I upgraded all my Windows PC's to Version 8.1 and later. ; ' {
I guess if all else fails I'll try and find a Windows 95 or 7 install disk and an old hard drive and install it.
On the 2001, it's tucked up under the dash on the passenger side above the kick panel - inside the truck, not under the hood.
Have you tried running your CD in compatibility mode? If you have a disk and don't want to hassle with a hard drive, you can install VirtualBox and install it in a VM.
