Center console shifter
Does anyone happen to know where can I get the wiring diagram for the center console shifter, I'm planning to do a swap from the steering wheel to the floor I look for that hidden connector that someone said should be there under the dash, well its not, so If somebody knows the wiring diagram so I can use the connector from the steering wheel to connect it to the floor shifter, Ill appreciate it Thanks
I don't know the answer, but you can get a $20 subscription for 1 month of access and see the real Ford service docs:
http://www.motorcraftservice.com/vdi...d=&kevin=rules
I can get you a diagram tomorrow, just make your own wiring harness like I did on my shifter swap
https://www.f150online.com/forums/19...e-shifter.html
Ive been wanting to do this mod also! Actually ive been looking for a set of OE leather seats and they all come with the flow thru. I was just considering removing the shifter on the console and building/fabing something to cover the hole or just make it look like a nook coin holder or phone holder.... But, now that i know the shifter can be made functional i think ill be looking into this!!! Good luck with the wiring and all, and be sure to keep us updated!!
UPDATE: Center Console Shifter
I'm 95% done, You'll see in the pictures the little things that I have left, but other than that all the major work is done, everything is working great,thanks to patman who share the wiring diagram to connect the floor shifter, one thing I notice that when I do the shifting the indicator in the cluster lights up to me is kind a neat and i didn't do anything on that it came out automatically. notice the gap triangle shape? the red handle, i dont know, may be I could live with that, the column cover I got it is ease to install so consider it done.
Before
[IMG][/IMG]
After...
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Before
[IMG][/IMG]
After...
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Hey I know I'm diggin this up from the cold grave here but. Memo your the only one that I have found that's done this conversion on a 09 newer truck I got a 8 month old 2011 xlt an I am doing this conversion looking for parts and information now can you shoot me a list of all the dash peices you used and do you know of any places selling just the gear shifter other than a dealer
