4 wheel drive problem
I have an 07 with a 5.4. In 2 wheel drive it drives fine. If i put it in 4 hi. The truck will every few feet lock up. You can hear the tires chirp. Its taken chunks out of the rubber. The front diff will get supper hot.
I rebuilt the transfer case it still does it. then tried swapping in a used one. I swapped the electric motor on the transfer case too. I rebuilt the front diff. still does it. I'm getting no codes on the computer. I really dont know what else to try.
Any suggestion please?
The only other thing i can think of is the vacuum solenoid for the locking hubs?
If you are running it in 4WD on hard surfaces ....
.... then you don't have a 4wd problem yet ....
.... what that truck needs is an owner who will read the owners manual.
Yep... sounds like they are treating its like AWD and driving it on hard surfaces.
I've never had "chunks" of tire taken off when using 4wd even on the driest and rockiest of soils. Mind you my truck isn't 4wd, but I've owned 4wds, my tractor is 4wd, and I've got 4wd work trucks, and never have experienced any of that unless I forget to turn it off and then I hear it bind up a little, then I turn it off.... but not drive around like that.
This is what makes auto manufacturers take away the fun of owning a vehicle that you have switches and ***** that control the vehicle dynamics.
I'm betting one of these days, there will be AWD F150s and SuperDutys... just because people can't read the damn manual or use common sense for their damn near $50k+ piece of equipment.
I for one have read your post a couple times .... again just now .... and I still think we nailed it.
I hate to jump on your back, but I agree with tbear853.
It reminds me of someone who goes to a doctor with an issue, but they don't correctly explain all of the symptoms they're having. Then when he/she doesn't diagnose their illness correctly, that doctor is a no good worthless so and so. I've seen it so many times...
