P0325 Code
Did you change it yet? I got this same code but if I clear the DTC it comes back within a few miles. Truck hesitates a bunch too...and the other day the chk engin light flashed...and the manual says thats a miss-fire. My spark plugs have 138k on them too...and I hear a tick tick from the motor that I think is the cam phaser.
Any update? I finally got plugs changed at 144k. Truck runs MUCH better and the ticking was a plug crossthreaded at the factory and finally had backed out and was like a exhaust leak making a ticking sound. I was getting dtc for both knock sensors too and changed both. I'm still getting the 2 dtc codes for the knock sensors. So what else can it be??? U said something about a clogged cat...can that cause that dtc? Mine might br clogging...I have new high flows I'm about to put on.
I own a 2004 4X4, 5.4 V8. I noticed the P0325 code every time my gas got down below a quarter tank. I added a bottle of "HEET", fuel treatment to remove water, every time I filled up for a couple tanks. I have not had the code again in the last 2 months. I'm guessing it was an Ethanol gas, cold weather problem.
