Quick question about the dome light in a XLT
Originally Posted by 4RDFMLY
Does anyone know witch fuse and witch relay controlls the dome light? Ive looked in the owners manual and either Im not seeing it or its not there. I see no listing for the map lights.
Well, that would be the Battery saver relay. It shares all those units.
I'm not sure where it is located, but I'll skim through the manual.
Chris
adding. The battery saver relay is on the main fuse box, at least according to the CD.
editing again...
It has the instrument cluster, the vanity mirror left and right, the various map lights etc. (those are different each body model).
But the air bag seems to be routed through the horn relay???
Does the horn work?
The stuff like the cluster (so the odometer will light up when you open the door) the domelights, the various lights, the Pats system, route through the delay circuit. I can’t verify the airbag light.
They all ground through the green bolt by the parking brake.
Did you just add something, work on something, repair something?
Chris
editing again...
Does the horn work?
Chris yes the horn does work. And yes I had my overhead console down so I could replace the map lights and when I put it back up I think I may have accidently pinched the wires to my Homelink add-on witch is tapped into the map light harness.
Objects in motion tend to stay in motion. Objects you touch tend to fall over...
Anyway let me know if you need any schematics, etc. I won't post them (copyright...) but I will e-mail you PDF's if you need em.
Chris
