Maintenance Question reg. Dot 3
Dot 3 brake absorbs moisture over time and loses it's effectiveness. I flushed my mustangs system and put in fresh valvoline synthetic dot 3/4. I haven't did my truck yet, although I'm sure it could use it.
I took a turkey baster and sucked out as much of the old fluid as possible and put in new. I then bleed each brake until good clean fluid comes out. Very easy.
It's a good idea to flush and fill the brake system with clean fluids every 2-3 years. Even though the brake fluid in the resevoir may look 'Clean', but if you start bleeding out the fluids from the bleeders, then you'll see just how black and dirty the fluid really is. It's cheap and easy to do (especially if you have a vacum bleeder), and your brakes will feel much better too.
I'm really beginning to think this is the problem with my truck. I have 107K and have only had one brake job at about 70K. My mechanic who just did an inspection said that pads are fine, but I get a periodic pulsing from my brakes. It's not a warped rotor because it only happens when the brakes are under load (pulling an unbraked trailer) or get hotter from extended use (trips or hot days). I think that my brake fluid has water in it and is boiling. Does this sound right to anyone.
I have a few questions somewhat on this topic.
1) Why does the brake fluid get dark so quickly? I changed my fluid a couple of years ago and it was dark again in 2 weeks. My wifes Nissan has never been changed and is still relatively clear after 5 years of hard driving.
2) Do those one man auto bleeders work and work for changing the fluid. (the type sold at say Autozone)
3) My front pads are worn very unevenly from inside pad to outside pad - could this be from improper caliper pin lubrication from the factory? The calipers do not seem to move freely when the I have compressed the piston. I was wondering since there seems to be a common belief that breaks wear out quickly on our trucks if the frozen movement of a caliper would cause premature wear of one pad and therefore require early replacement.
Thanks for any info
Dave
Thanks for any info
Dave
