Hi. I was wondering what it entailed to go from 5 stud 135mm rims with 14mm studs to the same in 12mm? Do I need to change out the studs? Or is it possible to bore out the holes in the 12MM rims?
you could probably drill out the holes. the wheel is positioned on the hub not the bolts. A lot of people run Lightning wheels which are 14MM holes on 12 MM studs with no problem. I see no reason you could drill the wheels to 14MM.
