Emergency brake light
Old 04-01-2002, 10:47 PM
97GreenLariat's Avatar
My emergency break light doesnt' come on anymore when the e-brake is on. I am over due for an inspection & think i need this to pass.
Old 04-02-2002, 07:35 AM
AjRagno's Avatar
Mine doesn't always come on either. I'm thinking that there is a loose connection between the E-Brake pedal and the instrument cluster.
I wish that I could tell you exactly where it failed but it's way too cold here to remove any dash panels looking for it.
Sometimes it works and other times not but there doesn't seem to be any logic to it.....
If yours stopped all together, it may be a simple as a burnt out bulb.
Old 04-02-2002, 07:01 PM
Ford4ever's Avatar
Probably just a bad switch on the e-brake pedal. I don't think the light is required for inspection as long as the e-brake works. At least i never pay attention to the light when i do inspections. BTW, i'm in NY, your state could be different.
-Jon
Old 04-02-2002, 07:09 PM
max mitchell's Avatar
97GreenLariat-
The light doesn't have to work. Try this--
http://www.txdps.state.tx.us/vi/insp...ejectsubmit=Go
Old 04-02-2002, 07:55 PM
Thanks. Today its working so i went & got an inspection. (still wasn't sure if I needed the light to pass)
Quick Reply: Emergency brake light
