!997 F 150 brake pedal shutter
Old 03-23-2019, 03:21 PM
bshapiro56's Avatar
Im sorta new at this but I have a 97 F150 and while coming to a stop the pedal dropped, started to shutter a bit then the pedal got hard. Had to put alot of pressure to stop it. I put a new master cyl and is doing the same thing. Stops great till it does what it's doing. Any help would be appreciated.
Old 03-23-2019, 03:37 PM
Could be the ABS module or the sensor in the rear axle.
Old 03-23-2019, 04:51 PM
bshapiro56's Avatar
Thanks but how would I find that out
Old 03-23-2019, 05:07 PM
bshapiro56's Avatar
Has rear drum brakes. ABS lights up on dash when key is turned on. goes off after it's started. Where would the abs sensor be?
Old 05-08-2019, 10:31 PM
jbravo316's Avatar
On my 1997 the sensor is on top of rear differential. Be careful removing because sensor on my truck came apart and half of it dropped back into rear end. Had to take rear cover off to get it.
Old 05-09-2019, 10:17 AM
Roadie's Avatar
Get someone to check for abs codes.
Quick Reply: !997 F 150 brake pedal shutter
