Resetting TPMS and got 2 beeps!
Due to damage I had to replace one TPMS sensor on my 2015 F-150. When I go through the proper procedure for relearning the system, I get 2 horn sounds instead of 1 after lowering the air pressure at the new sensor.
We have tried the procedure 3 times with this same result.
Does this confirm that the sensor is bad?
Haven't checked with the dealer yet.
More info: I did check with the E-bay seller who I bought it from. He says I bought the wrong one. I have e-mailed him proof that his compatibility chart on the sale said it WAS THE RIGHT ONE!
Complained to him about the high cost of dismounting the tire and a re-balance.
Waiting for his reply.
Interesting. When I check Tire Rack, they don't list sensors for a 2015 F150. That tells me they may be a Ford dealer item only.
https://www.tascaparts.com/auto-part...omponents-scat
Tasca has 2 choices, different frequencies. I'd call Tasca or a dealer with your VIN to see which one you need.
I have not had to do this yet on my '15 truck, but I used a tool for a '12 F250. I also know I had to read the instructions several times...
Make sure there are no other vehicles near yours, and that the old sensors are nowhere near you.
Did you use the instructions from the Owner's Manual?
If that did not work maybe your tire store or Ford can help?
May need to seek advice from the $90. an hour Ford dealer.
