2007 F150 TPMS replacement (compatibility ?).
Old Sep 22, 2014 | 12:06 PM
Fast351's Avatar
OK guys, my TPMS is throwing an occasional light even though the tires are aired up to 35 PSI. Batteries are probably going dead. Since I am having new tires put on next week, I would like to put in new sensors. Only problem, the 2007/2008 are kind of the bastard years for TPMS. The factory sensors are the banded sensors and are stupid expensive and require a special tool to install. So....
I have read a thread discussing a 2008 truck:
https://www.f150online.com/forums/wh...s-sensors.html
and looked on Oroteks website:
http://www.orotekusa.com/AppGuide.aspx
that both seem to suggest that the universal model will work.
Has anyone done this in a 2007 with success? I would really like to confirm before I spend $200 on TPMS sensors that may not work. I would also like to know about other valve stem mounted brands that have been successfully learned to a 2007 truck.
Thanks guys!
Old Oct 7, 2014 | 09:19 PM
Fast351's Avatar
Just a quick note to follow up. Ended up getting Schrader EZ Sensor 33000 TPMS units. My brother is a MAC Tools guy so he was able to borrow me the tool to program these for my specific model year, although you can buy them preprogrammed as well.
Took 5 minutes total to program them and after installing them it was easy to relearn the truck (cycle ign 3 times, hit brakes, cycle ign 3 times, light up each sensor).
ou can find more info here: http://www.ez-sensor.com/what-is-the-ez-sensor.html
