power steering issues
2008 f150 4x4 lariat 5.4L 6 in Rcx lift 35x12.50 nittos. At this point I'm on my 3rd power steering pump and my 2nd set of tie rods. The power steering is a little weak during normal driving but when moving slow or at a stop I have pretty much no power steering at all. The current pump whines louder than my exhaust is and I have no clue what to do. Is there any type of aftermarket pump that's stronger or just something else I can do to fix all my issues?
If any of those "couple of types" were not Mercon V, you've got some work to do. Regular power steering fluid is very damaging to these steering systems.
Pull the boot off the rack on both sides. If you see fluid in them, replace the rack in addition to the pump. If no fluid, try flushing the power steering with Mercon V. If that doesn't work, replace the pump.
Probably not, but worth a shot before throwing parts at it. Skip the high-dollar fluids for now. Odds are it would be wasted when the pump and/or rack has to be changed.
No additives, mystery fixes in a can, etc. Just plain Mercon V. Flush all the old crap out. Before doing that, check inside the rack & pinion boot for fluid leaking.
