Please help
Old Jan 31, 2014 | 07:29 AM
ShawnMC88's Avatar
Please help
I've been searching for an entire day and I can't find anyone with exact set up. I got a set of eagle alloy 079 for $100 I couldn't say no . My question is will they work when I lift my truck. They're 18x8.5 +35 offset with 6.25" back spacing. I want to run 35x12.5 18s bfg km2 tire. Any help is greatly appreciated. I got 2012 f150 4wd will be doing 6" lift. I'm also open minded about wheel spacers! Thanks
Old Jan 31, 2014 | 08:39 AM
il_duce's Avatar
Welcome to the forum! When you get a chance, go over to the introduction section and introduce yourself to everyone.
People run 35" tires with a 6" lift all the time. Considering I've even seen people run 35's with only a 2.5" level and stock rims, I'd say you'll be fine. I believe stock wheels have a +44 offset, so a +35 should be good. You may have to trim some plastic, but it shouldn't deter you. Maybe someone with a similar setup will jump on and give you a more definitive answer. But I think you should be good to go.
Old Jan 31, 2014 | 10:25 AM
ShawnMC88's Avatar
I appreciate your speedy response. I'm hoping I can run them. I'm hoping someone had similar set up that can chime in. I wouldn't mind running spacers to have it poke out an inch or so If that would help.
Old Jan 31, 2014 | 12:20 PM
wandell's Avatar
It depends on what lift you use. Several suspension lifts for the 04-14 F-150's require wheels with less backspacing, like 4.5 or 5 inches.
Old Jan 31, 2014 | 01:45 PM
ShawnMC88's Avatar
I'm looking at ordering rough country 6" soon
Old Jan 31, 2014 | 01:49 PM
ShawnMC88's Avatar
Looks like they want 4.5-5" BS So looks like I'm sol on these wheels?
Old Jan 31, 2014 | 01:52 PM
il_duce's Avatar
Might be. Sorry, I missed that you had posted the backspacing on your initial post.
Old Jan 31, 2014 | 03:13 PM
ShawnMC88's Avatar
It's alright. I should be able to sell em. Does anyone know of a company that sells black 18s with -12 offset for decent price?
Old Jan 31, 2014 | 03:16 PM
il_duce's Avatar
I'd start your search with discountire.com, tirerack.com, and maybe discountedwheelwarehouse.com. They usually seem to have the best deals available. Some even ship for free.
Old Feb 2, 2014 | 01:30 AM
ShawnMC88's Avatar
I appreciate all the help, I think I'm going to get xd addicts in 17" I just got to figure out offset and backspacing needed.
